Error! TimeShift.CheckOverfill - зависание видеоизображения и звука во время записи.
Пришлося перевключать канал.
В логе:
15:07:10.561 - * s:100 q:100 tr=278804 (0) Playing
15:07:10.714 - Error! TimeShift.CheckOverfill
15:07:10.715 - CChannelGraph5::Overfill !!!
15:07:10.715 - TimeShift.Cursor ShiftReadCursor 10000s gen 0
15:07:10.716 - ShiftReadCursor Error!!! (1)
15:07:11.559 - * s:100 q:100 tr=836412 (0) Playing
15:07:12.562 - * s:100 q:100 tr=278804 (0) Playing
15:07:13.557 - * s:100 q:100 tr=278992 (0) Playing
15:07:13.974 - Graph::SetVideoWindowRect {0 0 0 0}
15:07:13.987 - Api2BaseModule.OnDisplaySize
15:07:13.987 - dev: UpdateNetworkRecommendations 160x-1 -1x-1
15:07:14.558 - * s:100 q:100 tr=348552 (0) Playing
15:07:15.556 - * s:100 q:100 tr=278804 (0) Playing
15:07:15.961 - Error! TimeShift.CheckOverfill
15:07:15.962 - CChannelGraph5::Overfill !!!
15:07:15.963 - TimeShift.Cursor ShiftReadCursor 10000s gen 0
15:07:15.963 - ShiftReadCursor Error!!! (1)
15:07:16.557 - * s:100 q:100 tr=976472 (0) Playing
15:07:17.561 - * s:100 q:100 tr=278804 (0) Playing
15:07:18.556 - * s:100 q:100 tr=278616 (0) Playing
15:07:19.558 - * s:100 q:100 tr=278804 (0) Playing
15:07:20.557 - * s:100 q:100 tr=278616 (0) Playing
15:07:21.212 - Error! TimeShift.CheckOverfill
15:07:21.213 - CChannelGraph5::Overfill !!!
15:07:21.214 - TimeShift.Cursor ShiftReadCursor 10000s gen 0
15:07:21.215 - ShiftReadCursor Error!!! (1)
15:07:21.555 - * s:100 q:100 tr=766476 (0) Playing
15:07:22.557 - * s:100 q:100 tr=278804 (0) Playing
15:07:23.558 - * s:100 q:100 tr=348364 (0) Playing
15:07:24.557 - * s:100 q:100 tr=278616 (0) Playing
15:07:25.558 - * s:100 q:100 tr=278804 (0) Playing
15:07:26.265 - Graph::SetVideoWindowRect {0 7 1692 958}
15:07:26.281 - Api2BaseModule.OnDisplaySize
15:07:26.282 - dev: UpdateNetworkRecommendations 1936x1066 -1x-1
15:07:26.301 - Graph::OnVideoWindowPositionChanged
15:07:26.476 - Error! TimeShift.CheckOverfill
15:07:26.477 - CChannelGraph5::Overfill !!!
15:07:26.477 - TimeShift.Cursor ShiftReadCursor 10000s gen 0
15:07:26.478 - ShiftReadCursor Error!!! (1)
15:07:26.563 - * s:100 q:100 tr=836224 (0) Playing
15:07:27.557 - * s:100 q:100 tr=418300 (0) Playing
15:07:28.559 - * s:100 q:100 tr=278992 (0) Playing
15:07:29.560 - * s:100 q:100 tr=278616 (0) Playing
15:07:30.557 - * s:100 q:100 tr=278804 (0) Playing
15:07:31.676 - Error! TimeShift.CheckOverfill
15:07:31.689 - * s:100 q:100 tr=1184776 (0) Playing
15:07:31.755 - CChannelGraph5::Overfill !!!
15:07:31.756 - TimeShift.Cursor ShiftReadCursor 10000s gen 0
15:07:31.757 - ShiftReadCursor Error!!! (1)
15:07:32.562 - * s:100 q:100 tr=348928 (0) Playing
15:07:33.559 - * s:100 q:100 tr=279368 (0) Playing
15:07:34.556 - * s:100 q:100 tr=279556 (0) Playing
15:07:35.560 - * s:100 q:100 tr=278992 (0) Playing
15:07:36.559 - * s:100 q:100 tr=348552 (0) Playing
15:07:36.773 - Error! TimeShift.CheckOverfill
15:07:36.774 - CChannelGraph5::Overfill !!!
15:07:36.775 - TimeShift.Cursor ShiftReadCursor 10000s gen 0
15:07:36.775 - ShiftReadCursor Error!!! (1)
15:07:37.563 - * s:100 q:100 tr=1045092 (0) Playing
15:07:38.562 - * s:100 q:100 tr=644088 (0) Playing
15:07:39.612 - * s:100 q:100 tr=465112 (0) Playing
15:07:40.556 - * s:100 q:100 tr=222216 (0) Playing
15:07:41.559 - * s:100 q:100 tr=466052 (0) Playing
15:07:41.960 - Error! TimeShift.CheckOverfill
15:07:41.961 - CChannelGraph5::Overfill !!!
15:07:41.962 - TimeShift.Cursor ShiftReadCursor 10000s gen 0
15:07:41.963 - ShiftReadCursor Error!!! (1)
15:07:42.559 - * s:100 q:100 tr=272036 (0) Playing
15:07:43.557 - * s:100 q:100 tr=364532 (0) Playing
15:06:47.554 - ---state st=7 refp=1 13c3cad8
15:06:47.555 - ---state st=7 refp=1 13c3cad8
15:06:47.960 - Wait Timeshift 100ms
15:06:48.213 - Wait Timeshift 240ms
15:06:48.464 - Wait Timeshift 200ms
15:06:48.554 - ---state st=7 refp=1 13c3cad8
15:06:48.555 - ---state st=7 refp=1 13c3cad8
15:06:48.711 - Wait Timeshift 240ms
15:06:48.961 - Wait Timeshift 240ms
15:06:49.214 - Wait Timeshift 240ms
15:06:49.463 - Wait Timeshift 240ms
15:06:49.554 - ---state st=7 refp=1 13c3cad8
15:06:49.555 - ---state st=7 refp=1 13c3cad8
15:06:49.713 - Wait Timeshift 240ms
15:06:49.960 - Wait Timeshift 220ms
15:06:50.214 - Wait Timeshift 240ms
15:06:50.463 - Wait Timeshift 240ms
15:06:50.554 - ---state st=7 refp=1 13c3cad8
15:06:50.555 - ---state st=7 refp=1 13c3cad8
В обеих частях лога упомянут Таймшифт, хотя он у меня выключен.
Не могу выложить папку Проглогс, появляется надпись, что файл слишком большой.
Re: Error! TimeShift.CheckOverfill - зависание видеоизображения и звука во время записи.
timeshift не выключается а ставится минимального размера. На минимальном размере можно получить переполнение.
А куда девать данные которые приходят быстрее чем просмотр?
Другое дело что на сетевых каналах это должно быть не часто. Стабильно на канале проявляется? ссылку можете дать?
Ссылку не могу, потому что меня могут забанить. Если это не зависит от записи, то в первый раз такое. Я в первый раз такое вижу. Но вы говорите, что "на минимальном размере можно получить переполнение"? Значит, если я включу таймшифт в памяти, то я смогу избежать повторения подобного в дальнейшем?
Sun Apr 30, 2023 12:51 pm
Да. Лучше включить. И проверить винчестер. Сбойные сектора могут запросто такое давать. Скорость записи начинает отставать ит вопросизведение ...
Спасибо, проверю.
