First i will say hello to whole DVB family.
My english is bad.
I'm new user fo ProgDVB and I'm stuck on the begining.
Can anyone tell me posible reasons of black screen?
DVB receiver is ok.(green circle in sistem tray says status OK)
Channel list is on(on the left side of screen),Diseq ok(catch hotbird).
Latest S2emu and latest softcam key is instaled.
Cannot see any program (even not decoded)
PLIIIIZZZZ. HELP.
Hello zoroo
First Of All We Don't Say Anything Here About Plugins and ke ys
The Problem maybe is codecs / filters trie some other like DX9, Make Sure Direct Draw is available.
Trie Overlay at divice properties or check Bob or Software Scall. Sometimes when Min or Max Overlay Get Some Problem...
or trie to uninstall any codec like k-lite and then reinstall.
If you got SS1 check if you got Picture from Composite cable.
my stuff:
1st PC: Core2Quad (2.5Ghz), ASUS Proximus Extreme (1007), 2GB ram, nvidia 9600GT*2 (PCIe) + 7950GX2,
< 1stDVB - TechnoTrend S2300 + C.I. /Driver Technotrend 219h>
and < 2ndDVB - TechnoTrend S2300 /Driver Technotrend 219h>.
WinVista32 Ultimate. ProgDVB 5.x
2nd PC: AMD 4600+ X2 (2.51Ghz), GIGABYTE GA-K8NSC-939 ( F8 ), 3GB ram, nvidia FX5950ultra (AGP).
< 1stDVB - Hauppauge NEXUS-s/Driver Technotrend 219h>
and < 2ndDVB - Hauppauge NEXUS-s + C.I. /Driver Technotrend 219h>.
WinXP 32PRO. ProgDVB 5.x
3st PC: AMD 4200+ X2 (2.2Ghz), Asus A8n32-SLI Deluxe, 3GB Ram, Nvidia 9600gt 512mb (PCI-E),
<1stDVB - Hauppauge NEXUS-s /Driver Technotrend 219h>
and <2ndDVB - TechnoTrend S2300 + C.I. /Driver TechnoTrend 2.19h>.
WinVista 32 Ultimate, ProgDVB 5.x
LNB (13E,19E,39E,16E,42E,30W,1W,5E,26E,28E)
It's hard to help on technical issues, when no technical details are given, on DVB hardware, driver, versions, whatever else.
BTW, do you find stations at scanning?
Do you get EPG or TXT on some?
Do you have good level / quality readings?
If not using a hardware decoder equipped premium card in heardware mode, you MUST have an MPEG2 codec installed to get sound and vision.
ProgDVB comes with a time limited demo version of elecard, which can be installed by use of the file 'register.bat', that's located in the 'Filters' subfolder.
You were asked to do so in ProgDVB install routine...
You may as well use other codecs that are available system wide on your computer, by selecting from the audio / video settings.
There's quite a lot to read here on codec issues.
Also read at the old forums at
http://forum.progdvb.com/old/ubbthreads.php
And YES, we are only talking legal use here, either FTA or CI / CAM / subsdriber card based.
Definitely no software decryption disussion here.
