How Does This One Connected With ProgDVB?
Is This only For ProgDVB folder??? Trie to delete "desktop.ini"
But i think it's Windows Problem (from Registry)
(Or Something Like This: Remove text from desktop icons
Posted 2/15/2007 by Steve Sinchak - Total Views: 6,201 - Views Today: 10
Removing the text below an icon on your desktop has been a classic Windows tweak for years. In Windows Vista, the same old tweak works.
Right click on the icon and select Rename.
Then hold down the ALT key and type in 255 on your right keypad. If you are on a laptop turn on numlock and use the K and I keys to enter in 255. This is the code for a space.
Hit Enter when you are done.
If you want to remove the text from multiple icons then make sure that you do ALT + 255 a different number of times for each icon. )
my stuff:
1st PC: Core2Quad (2.5Ghz), ASUS Proximus Extreme (1007), 2GB ram, nvidia 9600GT*2 (PCIe) + 7950GX2,
< 1stDVB - TechnoTrend S2300 + C.I. /Driver Technotrend 219h>
and < 2ndDVB - TechnoTrend S2300 /Driver Technotrend 219h>.
WinVista32 Ultimate. ProgDVB 5.x
2nd PC: AMD 4600+ X2 (2.51Ghz), GIGABYTE GA-K8NSC-939 ( F8 ), 3GB ram, nvidia FX5950ultra (AGP).
< 1stDVB - Hauppauge NEXUS-s/Driver Technotrend 219h>
and < 2ndDVB - Hauppauge NEXUS-s + C.I. /Driver Technotrend 219h>.
WinXP 32PRO. ProgDVB 5.x
3st PC: AMD 4200+ X2 (2.2Ghz), Asus A8n32-SLI Deluxe, 3GB Ram, Nvidia 9600gt 512mb (PCI-E),
<1stDVB - Hauppauge NEXUS-s /Driver Technotrend 219h>
and <2ndDVB - TechnoTrend S2300 + C.I. /Driver TechnoTrend 2.19h>.
WinVista 32 Ultimate, ProgDVB 5.x
LNB (13E,19E,39E,16E,42E,30W,1W,5E,26E,28E)
Bi2Lmetall wrote:How Does This One Connected With ProgDVB?
the problem not found in old version of progdvb and not found in any other folder
found only in
C:\ProgDVB\plugins
and
C:\ProgDVB\modules
do you think this is virus infect the windows vista ?
and thank you
Did you delete desktop.ini?
my stuff:
