ProgDVB + TT Budget S-1500 + CI + CAM Dragon может работать?
1 post
Serega
Serega
Wed Nov 29, 2006 9:32 am
#1 by Serega
Имеется карта TT Budget S-1500 + CI и CAM Dragon (T-Rex).
ProgDVB не хочет видеть CAM. (Родной софт от TT и триальный MyTheater с CAMом работают нормально).
Работает ли у кого нибудь ProgDVB с CAMом в такой конфигурации? Может надо модуль или плагин какой к нему? Подскажите пожалуйста!
  • Wed Nov 29, 2006 9:55 am
1 post
Return to “Russian”
Re: Two Bugs in v3 portable
I am not can repeat that. Please try last version of ProgTV. Still same?
Prog, Fri Sep 11, 2026 7:30 am
Thanks for report. I am retest that in near time.
Prog, Thu Sep 03, 2026 7:39 am
Hi there. I thought the portable had sorted out a bug I found in the windows app version, but sadly not. It seems that i
fredphoesh, Wed Sep 02, 2026 8:18 pm
Re: ProgTV3 portable
edit
fredphoesh, Wed Sep 02, 2026 7:46 pm
  • It is currently Mon Sep 14, 2026 4:00 pm
