I have a Problem with the Transponderlist for DVB-C
We have an 256 Quam Modulation on some channels.
I modified then Transponder-List to 256 QUAM
when I now open then Scan Transponder, der will be an Error.
All other Modulation (128 QUAM, 64QUAM) works fine. But the 256QUAM kan not be loaded.
Manual I can search for these Programms.
Here my Transponder-List and the Error Message:
I hope you can help me
___________________________________________________________
[CABTYPE]
1=01
2=Cabel (dvb-c)
3=C
; Frequency(KHz), Symbolrate(Ks/s), QAM
[DVB]
0=106
1=50500,6900,0
2=57500,6900,64
3=64500,6900,64
4=71500,6900,64
5=78500,6900,64
6=85500,6900,64
7=92500,6900,64
8=99500,6900,64
9=107500,6900,64
10=113000,6900,64
11=121000,6900,64
12=128500,6900,64
13=135500,6900,64
14=142500,6900,64
15=149500,6900,64
16=156500,6900,64
17=163500,6900,64
18=170500,6900,64
19=177500,6900,64
20=184500,6900,64
21=191500,6900,64
22=198500,6900,64
23=205500,6900,64
24=212500,6900,64
25=219500,6900,64
26=226500,6900,64
27=233500,6900,64
28=240500,6900,64
29=247500,6900,64
30=254500,6900,64
31=261500,6900,64
32=268500,6900,64
33=275500,6900,64
34=282500,6900,64
35=289500,6900,64
36=296500,6900,64
37=306000,6900,64
38=314000,6900,64
39=322000,6900,64
40=330000,6900,64
41=338000,6900,64
42=346000,6900,64
43=354000,6900,64
44=362000,6900,64
45=370000,6900,64
46=378000,6900,64
47=386000,6900,64
48=394000,6900,256
49=402000,6900,256
50=410000,6900,256
51=418000,6900,256
52=426000,6900,256
53=434000,6900,256
54=442000,6900,256
55=450000,6900,256
56=458000,6900,64
57=466000,6900,64
58=474000,6900,64
59=482000,6900,64
60=490000,6900,64
61=498000,6900,64
62=506000,6900,64
63=514000,6900,64
64=522000,6900,64
65=530000,6900,64
66=538000,6900,64
67=546000,6900,64
68=554000,6900,64
69=562000,6900,64
70=570000,6900,64
71=578000,6900,64
72=586000,6900,64
73=594000,6900,64
74=602000,6900,64
75=610000,6900,64
76=618000,6900,64
77=626000,6900,64
78=634000,6900,64
79=642000,6900,64
80=650000,6900,64
81=658000,6900,64
82=666000,6900,64
83=674000,6900,64
84=682000,6900,64
85=690000,6900,64
86=698000,6900,64
87=706000,6900,64
88=714000,6900,64
89=722000,6900,64
90=730000,6900,64
91=738000,6900,64
92=746000,6900,64
93=754000,6900,64
94=762000,6900,64
95=770000,6900,64
96=778000,6900,64
97=786000,6900,64
98=794000,6900,64
99=802000,6900,64
100=810000,6900,64
101=818000,6900,64
102=826000,6900,64
103=834000,6900,64
104=842000,6900,64
105=850000,6900,64
106=858000,6900,64
System.IndexOutOfRangeException: Index was outside the bounds of the array.
at ProgDvbNet.ScanTransponderForm.ScanPointsComboBox_SelectedIndexChanged(Object sender, EventArgs e)
at System.Windows.Forms.ComboBox.OnSelectedIndexChanged(EventArgs e)
at System.Windows.Forms.ComboBox.set_SelectedIndex(Int32 value)
at ProgDvbNet.ScanTransponderForm.ScanTransponderForm_Shown(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnShown(EventArgs e)
at System.Windows.Forms.Form.CallShownEvent()
at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
at System.Threading.ExecutionContext.runTryCode(Object userData)
at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbacks()
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
ProgDvbNet
Assembly Version: 5.9.1.0
Win32 Version: 5.09.1
CodeBase: file:///C:/ProgDVB/ProgDvbNet.exe
EngineApiWrapper
Assembly Version: 1.0.2739.20953
Win32 Version:
CodeBase: file:///C:/ProgDVB/EngineApiWrapper.DLL
msvcm80
Assembly Version: 8.0.50727.762
Win32 Version: 8.00.50727.762
CodeBase: file:///C:/WINDOWS/WinSxS/x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_6b128700/msvcm80.dll
System
System.Drawing
IPDev.Skins
Assembly Version: 1.0.8.0
Win32 Version: 1.0.8.0
CodeBase: file:///C:/ProgDVB/IPDev.Skins.DLL
Accessibility
System.Design
enabled.
For example:
<configuration>
</configuration>
the actual versions have a scanning bug......
viewtopic.php?p=4308#4308
same for progdvb 5.xx....so use older version....
