Hi,
I use windows 11 and when i open the latest version of progdvb ProgDVB7.65.9Pro.exe
and click on any iptv channel it crahses
i checked the windows event log and here it is:
Faulting application name: ProgDvbNet.exe, version: 7.65.9.0, time stamp: 0x67e66de8
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0xc0000005
Fault offset: 0x0f980806
Faulting process id: 0x4154
Faulting application start time: 0x1DBA25DFC98BE83
Faulting application path: C:\Program Files (x86)\ProgDVB Professional\ProgDvbNet.exe
Faulting module path: unknown
Report Id: 295accc9-8989-4a00-ad17-7824f1305cbd
Faulting package full name:
Faulting package-relative application ID:
Application: ProgDvbNet.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: exception code c0000005, exception address 0F980806
Re: progdvb crashes when cliked on iptv channel
#6Please send me link on this channel for test. Or/and logs.
#7i enabled logging and attached the log
- ProgLogs250404-2240.zip
- (16.35 KiB) Downloaded 324 times
#8Are you sure in crash in last 7.66? I am not can repeat it.
#9yes it did
i think there is a conflict maybe in the dotnet version installed or maybe some codec problem
it is interesting that it worked before and suddenly it stopped. since firs time i did not change anything in progdvb the problem maybe from the windows 11 updates
#11yes ofcourse i have completely deleted and reinstalled .done everything i would think of.none of them works.
even disabled antivirus.
#12btw, do you stack information about this crash? For example is error dialog
#13i installed version 7.53.08 x86 NOT 64 bit and it worked
#14Crash only in x86? Please not remove old x86 version. I must fix this problem.
#15btw, do you have addition settings in TV sources? User-agent or?
