ProgTV 3.8.3 - Trail Period Expired
MG317
MG317
Tue Feb 18, 2020 1:54 pm
#1 by MG317
On my Windows 11 machines, I am now getting this message in a pop-up box -
WinLicense
Your trial period has expired. No more days left.
Please, register this software at https://progdvb.com
This behavior started with 3.8.2. And 3.8.3 shows the same problem.
I'm unable to load the program now. How can I fix this?
Michael
  • Sat Sep 06, 2025 4:51 pm
Re: ProgTV 3.8.3 - Trail Period Expired
Do you have license?
In any case - try install previous version of ProgTV. I'll test it again tomorrow
  • Sun Sep 07, 2025 3:15 am
MG317
MG317
#3 by MG317
I uninstalled and reverted to version 3.8.0 to resolve the issue.
Yes, I have a license. I bought the license in 2020. I have changed the PC it was registered to, so I haven't been able to use the license. I quit trying to figure out how to do that.
  • Mon Sep 08, 2025 12:48 pm
#4 by Prog
Try install 3.8.4 version. And check data in registration dialog.
  • Tue Sep 09, 2025 5:51 am
MG317
MG317
#5 by MG317
The Name, Email, and Key fields are blank.
There are numbers in the HID field. Do you want them?
I have installed 3.8.4 and it is working as expected!
Thanks
  • Wed Sep 10, 2025 3:11 pm
Return to “ProgTV Windows”
Re: Two Bugs in v3 portable
I am not can repeat that. Please try last version of ProgTV. Still same?
Prog, Fri Sep 11, 2026 7:30 am
Thanks for report. I am retest that in near time.
Prog, Thu Sep 03, 2026 7:39 am
Hi there. I thought the portable had sorted out a bug I found in the windows app version, but sadly not. It seems that i
fredphoesh, Wed Sep 02, 2026 8:18 pm
Re: ProgTV3 portable
edit
fredphoesh, Wed Sep 02, 2026 7:46 pm
  • It is currently Sun Sep 13, 2026 1:22 pm
