Hi! First of all, thanks for the app, it's my favorite iptv app, but now i'm having a little issue with the recently versions of the app...
Basically, the color of the video is to much clear or bright, the blacks are very, i don't know how to say it, like grays... or so.
I already explorer the optións in the playback settings. i can't match the color just how i like it... actuallly, i don't touch anything in the playback settings, like never, after installation.
Currently i using the version 3.08.06, i can't install versions 3.8.7, 3.8.8 and the new 3.9.1, tried to use the new portable versions, but same problem... video color is just not good for me. Can't enjoy it.
Sorry my english.
Thanks!
Re: Issues with the video color in new versions.
#2Please check playback settings in ProgTV. Do you use ProgDVB Engine in both case? And check video renderer.
#3Yes, in both case, I have the same settings. Always install new versions and use without change anything, the current settings stay the same.
Already changed video render and post processor settings, Can't match even a little the color...
Thanks for the answer...
#4Checking the new version, ProgTV 3 x64 3.9.2 (normal installer and portable), same issue, It's like the color black is really black in 3.8.6 v, but in the other new versions is like the black is washed or something... Will continue changing setting, see how it goes.
Thanks so much man!
Thanks so much man!
