running raseberry tv on progdvb , slow motion and choppy
prop
prop
Thu Sep 18, 2025 12:03 pm
#1 by prop
i have it running on 2 other windows devices with no problems . i bought a new subscription for a third device and it!s unwatchable, cutting in and out and in slow motion.
  • Sun Dec 14, 2025 11:59 pm
Re: running raseberry tv on progdvb , slow motion and choppy
Check CPU load. Possible this device too slow. Also check internet connection.
  • Wed Jun 24, 2026 6:58 pm
Return to “ProgTV Windows”
Re: Two Bugs in v3 portable
I am not can repeat that. Please try last version of ProgTV. Still same?
Prog, Fri Sep 11, 2026 7:30 am
Thanks for report. I am retest that in near time.
Prog, Thu Sep 03, 2026 7:39 am
Hi there. I thought the portable had sorted out a bug I found in the windows app version, but sadly not. It seems that i
fredphoesh, Wed Sep 02, 2026 8:18 pm
Re: ProgTV3 portable
edit
fredphoesh, Wed Sep 02, 2026 7:46 pm
  • It is currently Sun Sep 13, 2026 1:22 pm
