ProgTV using Sat-ip not working
aloisr
aloisr
Sat Jul 18, 2026 7:46 am
#1 by aloisr
ProgTV crashes after searching for channels.
  • Sat Jul 18, 2026 7:51 am
Re: ProgTV using Sat-ip not working
Do you have scanned channels? Crash after open one of channels?
  • Sat Jul 18, 2026 9:17 am
#3 by Prog
I plan remake sat>ip support in next 2-3 months. Please mail me if you like help me with test.
  • Sat Jul 18, 2026 9:18 am
aloisr
aloisr
#4 by aloisr
It craches on beginning of scanning.
I you need further instructions i am
happy to help you.
greeting
  • Sat Jul 18, 2026 9:30 am
#5 by Prog
Please enable logs in ProgTV and send me logs after next crash https://www.progdvb.com/pam
  • Sat Jul 18, 2026 10:52 am
aloisr
aloisr
#6 by aloisr
Export log File did not work. Created a empty archive. But i will send the Log with email (alois-riedl@gmx.at). On the site named sources there is a field named Host and there i type the IP of my server?
  • Sat Jul 18, 2026 12:21 pm
aloisr
aloisr
#7 by aloisr
Email sent.
  • Sat Jul 18, 2026 12:25 pm
#8 by Prog
  • Sun Jul 19, 2026 6:41 am
aloisr
aloisr
#9 by aloisr
  • Sun Jul 19, 2026 5:17 pm
Return to “ProgTV Windows”
Re: Two Bugs in v3 portable
Thanks for report. I am retest that in near time.
Prog, Thu Sep 03, 2026 7:39 am
Hi there. I thought the portable had sorted out a bug I found in the windows app version, but sadly not. It seems that i
fredphoesh, Wed Sep 02, 2026 8:18 pm
Re: ProgTV3 portable
edit
fredphoesh, Wed Sep 02, 2026 7:46 pm
Re: 7.72 — three reproducible…
demux in ini or in gui options. Of course gui more simple. LAVSplitter not used. I am not author of LAV codecs and not
Prog, Tue Sep 01, 2026 3:15 pm
  • It is currently Fri Sep 11, 2026 4:35 am
