KNC One DVB-C problems
Hi all,
I have several issues with my new KNC One DVB-C card and ProgDVB.
When I start channel search, it doesn't find any channels. However I can do a transponder search and then find the channels. But this is annoying because i have to enter each frequency manually. :roll:
The other issue is that the quality is always at 100% and level is always 0% - no matter if the channel found via transponder search is working fine. 4.x and 5.x have both the same issue. :cry:
With my old technotrend card I was able to find channels and show the correct quality/level values.
It also doesn't seem to be a software issue - my xp is a clean & fresh install and I still have the same problems like before. DVBViewer also works with this card (able to find channels, show level etc. - but other issues like regular crashes or hangs in fullscreen mode etc. - so this ain't an alternative :evil:).
It also seems that I am not the only one with a KNC One card having Problems with ProgDVB and channel search/level display - at least google says that :?
I hope there is a solution cause I really like ProgDVB, esp. as free software. I prefer donation instead of paying for software that you can't test before you have to pay (like DVBViewer). 8)
Any help appreciated!
Regards,
Pac
depends on the driver of your dvb card ...
depends also on the driver of your dvb card ...
the KNC One DVB-C is not well supportet in progdvb...
