I read posts of others with this device not started etc. I DL the earlier version 4x of ProgDVB and load just now, and patch the registry as per forum answer here:
viewtopic.php?t=1128&sid=1ec4fd4dd3d795 ... e198173c0e
After this - the problem (device not started) is much worse, as after that DNS error window the MS contact window pops up and once cancelled the whole ProgDVB shuts down. This is a worse or equally useless result than the later ProgDVB 5x (ProgDVB5.11.3Std.exe) I used initially, before finding that forum post/answer advice. Also that post is still unanswered from the last question put - which is the same problem as I have now.
So - main question - is there a way to get progDVB (any version) to run on a Skystar 1 CI? Can someone post the Progdvb version that is best to try with, together with any more registry or INI file edit necessary to do this?
Best regards to all
