I have an old Telemann sm200D (SM200DPA) card.
It is still running the old driver (V1.00), firmware (V1.02) and application (1.02)
I cannot seem to get the updated 1.11 drivers from the Telemann website anymore.
1. Can you point me to a current location please?
I have moved and renamed the sm200D dll as Sky300.dll. ProgDVB recognises the card after rebooting the program once, occasionally twice. I then use DiSEqC to add a known MPEG 2 stream to the recognised card. The LNB is also recognised.
When I go to Channel Search however, I do not achieve "LOCK" on a previous Telemann Application verified, locking and high quality signal.
Could you recommend an older version of Prog DVB, with the updated 1.11 card drivers please, or do I have to fall back onto Windows 98SE where the card was working previously (with a very old ProgDVB version I no longer have!) ?
Thanks for any help offered.
David
