SkyStar 2 and motor,does it work? and how easy is it?
this is my 1st post here so Hello everyone
i have SkyStar 2 for a while now and its working fine with hotbird and astra 1 with 2 lnb's now i want to install a motor and I'm not sure if it will work fine with progdvb or not. i now live in the Netherlands and i want to receive the nilesat but the signal is very weak so i wonder if it will be easy to position the dish with progdvb or its going to lose it ? i see that i can use DISEqC12.module but is the any english guide how to set it up and us it?
thanks
The SkyStar 2 cannot directly drive a motor as it cannot deliver enough current. If you try to drive the motor directly you may burn your card out.
