Version 4.88.4 of this freeware somehow WRECKED my new Hauppauge HVR-3000 card !!!!!!! Using the DVB-T device it found all channels, but when I tried to start the DVB-S device inside the Options the program gave some error message, hung and could not be terminated by the task manager. After this, even the Hauppauge Software WinTV did not display any picture anymore! Before everything worked fine! I only wanted to find out, what ProgDVB can do.
I tried several restarts also with disconnecting the power cable off the PC, unpugged the card from PCI bus, plugged it back in, re-installed the drivers, restored a Windows-backup-image from before I installed the card the first time and re-installed the drivers & software again - no sucess. The card IS broken!!! I have to send it back now!!!
ProgDVB does not touch any device directly, it connects over the device file to the driver.
As it does not even have to load a firmware for that hardware this way, there should be no other way, to damage it in any way, than by a bad driver.
And that's not made by Prog.
However, something nasty may have happened to some of your Windows components, like DirectX, a codec, a part of the VGA driver or similar.
Besides, this may also be 'just' a temporal coincidence.
Best to do would surely be, to test again on another machine, or on a fresh Windows, perhaps on another hard disk (to avoid losing anyfhing on testing)..
... might have been of some importance...Some error message
