Symbolrate 6875 (I tried your 68750 - is there a typing error in the settings table ??)
May well be.
But generally, values are only good together with units.
This should be ksps (kilo symbols per second).
In Europe, a cable TV channel is either 7 or 8 MHz wide, by this a data rate of 68750 ksps (< 68 million bits per second) simply can't be done.
That's even to much for most satellite transponders, which are up to about 30 MHz wide these days.
Special modulation methodes like QAM* or *PSK give more than one bit per Hz of bandwidth, but redundancy for error correction reduces again, to approximately 1 bit per Hz, in most cases.
However, as long as it lists resp. accepts the values and parameters without complaining, ProgDVB should be able to handle them.
But drivers and hardware have to cooperate, of course...
