Problem with ProgDvb and Kword card
Hi to all!
I have a problem with my new pc: progdvb and my Kword card doesn't like one another.
When i go to Device List i can't find the Kword entry in the list :(
I have used progdvb with the same card, but with the old pc that went broken...the card isn't broken because i tried to use it to capture analog stream and it is ok...
I try to search the file Kword.device in the modules directory of progdvb root directory but the file is present, i tryed different version of progdvb but all of these give me the same problem :(
What can i do?
My pc configuration is:
-Win xp prof sp2
-cpu: intel quad q6600
-4gb ram
-asus p5k ( chipset p35 )
Try our search function on kworld
BTW, that hardware should have a full name...
Does the original application work?
Try to remember what you had to do, before getting it to work with ProgDVB for the first time.
Does it use BDA or standard drivers?
Once again:
Juergen wrote:Does the original application work?
If it's BDA, this is necessary.
Juergen wrote:Does it use BDA or standard drivers?
Look into system control, hardware
Excuse me! i didn't see your post but only the other one.
The original application of the card in dvbs but it works...
i used standard driver of the card, the same that works with the old pc....
is the card broken? :(
excuse me
Well, if the original application works fine (for DVB), the hardware should be OK.
So use our search function (again) on kworld, maybe you find some more hints.
