PROBLEM TT- 2400 at startup
I have a really big problem! :( :( :( Please help me!
I bought a TechnoTrend S-2400. I have installed ProgDVB, and at startup this program crashes down with an typical error "ProgDVB does not work any more!" Error module name BDA.Device... The driver is correctly installed. I have Windows Vista 32-bit with Intel Core Duo processor and 2 GB of main memory.
Please help me!
Best Regards
ovolix
Hello!
Thank you, for your fast reply!
I have copied this file into the folder c:\program files\progdvb\modules.
When I connect my TT S-2400 to my PC and then I start ProgDVB this Program crash down with a Error from Windows: "Progdvb does not work anymore.
Details of the Error:
Description:
Stopped working
Problem signature:
Problemeventname: APPCRASH
Application Name: ProgDvbNet.exe
Application Version: 5.12.8.0
Application Timestamp: 4787abb4
Fault Module Name: ProgDvbEngine.dll
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 4787ac45
Exception Code: c0000005
Exception Offset: 000037f6
Best Regards
ovolix
Did you extract the content from the ZIP first?
ProgDVB can't open ZIP.
I can already watch via satellite with the program which was included by the TT-S2400
Only with ProgDVB i have this problem, because this program crash down at startup!
Is it possible, that the driver is the problem?
