I installed it in my new Dell E6550 2.33ghz Intel Core 2 Duo CPU with Vista 32bit OS.
I connected it up to the Eurobird 1 & Astra 2a/2b/2d satellite system that I use to get all the FTA Sky Channels.
As this worked fine on my old PC I thought there would be no problem setting it up on the new one.
I was wrong.
I Used the Disc but downloaded the updates for both the ProgDVB s/w and the driver for the PCI.
First I tried ProgDVB V5 but i kept on getting bombed out at the start. I tmay have been because .NET Framework may not be installed.
Then I tried ProgDVB V4. This opened and I set it up for the Genia tech Card but i got a Quality % of 1 and a Level % of 52 with no fluctuation at all through the 97 different transponder settings.
I then tried some of the other listed devices and 2 Conexant BDA's gave me a Level % of 100 but a Qualit % of 0. Again I went through all 97 transponder settings.
Am I doing something wrong here?
Can someone point me in the right direction?
Regards,
Desperate
