I would like to report the following bug (and it's solution
ProgDVB 5.13 and all previous V5.x seem to have an incorrect frequency preset entry for DVB-T. It is regarding Germany/Munich's VHF DVB-T channel 10
(Germany/Munich programs on this channel: Das Erste, Phoenix, arte, Eins Plus)
Both the "Germany/Munich" preset and the "all regions" preset, where it scans 57 DVB-T channels do not succeed in finding those channel 10 programs.
To locate them, I called menu option "channel list" -> "scan transponder", selected channel 10, then modified the preset frequency from 212.000kHz to 212.500 and then lock, then scan and then the channel 10 programs where successfully found.
I guess it's a ProvDVB5 problem, because ProgDVB 4.x does not have this DVBT-channel-10-find problem.
You might want to check that and maybe modify the frequency preset in V5. Or maybe V5 skipps scanning 212500kHz due to a bug?
