I am using twinhan 1020 vision plus with ProgDVB5.13Std. In device list i select
WDM drivers.But when i wat to use subtitle for TV and when i select subtitle
prog crash and close it self.
Even when i want to watsh TV without subtitle it cant been start.
When i again start prog last chanel that i was select work but when i want to
select new tv it cant be started.I frst select tv channel and then close prog
and start it again and i can watch only that channel,when i want to watch new
i always must do it like i discribe it.
What satellite(s) are you on?
Please also name some example stations.
Are that subs TXT based (with a TXT page set for it in channel props) or ETSI (using the extra module)?
Did you test with any 4.x version?
For example.I start prog and wtach on satelite THOR provider RCS
VIASAT HISTORY and when I go to ANIMAL PLANET on the same provider,and satelite program crash it self.I am using serbo-croatian (pid:903
So, you are talking about crypted channels?
But you are NOT talking plugin related issues here, aren't you ???
Stay with FTA stations or give precise details on your original subscriber card usage, please...
BTW, it would have been a pretty friendly gesture, to provide us with elementary details, like position (oh yes, as there are quite a few to look through...), transponder frequency (same).
For example, I don't find a provider 'RCS' listed on lyngsat or satcodx tables for Thor 2/3.
Perhaps that's due to my occasionally limited patience, but even my day does not have more than 24h...
See, actually we can't look over your shoulder or read your mind.
So, what to do now
So, what to do now
On DISCOVERY CE i cant find subtitle for "serbo-croatia",but on alt-dvbI
found but alt is not suport for that kind of subtitle.On Discovery on alt-dvb
pid 901 subtitle for "serbo-croatia" but in PROG there is nothing.
