I am using version 5.13.03 with a Freecom DVBT USB stick. PC is running Windows XP SP2. AMD Athlon 3800 2.4 GhZ, 1GB Ram.
Can view live OK, can record live OK though I've only tried a few minutes.
If I select EPG, then select a program and Record, orif I select Record then [Add] I gt the following Unhandled Exception:-
System.Resources.MissingManifestResourceException: Could not find any resources appropriate for the specified culture or the neutral culture. Make sure "..resources" was correctly embedded or linked into assembly "ProgDvbNet.EPG" at compile time, or that all the satellite assemblies required are loadable and fully signed.
at System.Resources.ResourceManager.InternalGetResourceSet(CultureInfo culture, Boolean createIfNotExists, Boolean tryParents)
at System.Resources.ResourceManager.GetResourceSet(CultureInfo culture, Boolean createIfNotExists, Boolean tryParents)
at System.ComponentModel.ComponentResourceManager.FillResources(CultureInfo culture, ResourceSet& resourceSet)
at System.ComponentModel.ComponentResourceManager.ApplyResources(Object value, String objectName, CultureInfo culture)
at System.ComponentModel.ComponentResourceManager.ApplyResources(Object value, String objectName)
at ..()
at ...ctor()
at ProgDvbNet.SchedulerForm.(Object , EventArgs )
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.832 (QFE.050727-8300)
ProgDvbNet
Assembly Version: 5.13.3.0
Win32 Version: 5.13.03
EngineApiWrapper
Assembly Version: 1.1.0.4
Win32 Version:
msvcm80
Assembly Version: 8.0.50727.762
Win32 Version: 8.00.50727.762
CodeBase: file:///C:/WINDOWS/WinSxS/x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_6b128700/msvcm80.dll
System
System.Drawing
ProgDvbNet.bc
Assembly Version: 1.0.1.1
Win32 Version: 1.0.1.1
IPDev.Skins
Assembly Version: 1.2.10.0
Win32 Version: 1.2.10.0
ProgDvbNet.EPG
Assembly Version: 1.0.0.5
Win32 Version: 1.0.0.5
Accessibility
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
System.Design
enabled.
For example:
<configuration>
</configuration>
Came out on sunday, in the evening.
The usual place...
Look here:
http://progdvb.com/download_progdvb5x.html
The usual place...
Look here:
