subj. Special is German, Franch and Spanish.
Of couse I give key of ProgDVB Pro for translate.
OS : Win XP SP2
CPU : P4 Intel 3.00 GHz "HT"
Memory : 2 GB
DVB-S : Sky Star 2 (2.6D) ( 4.4.0 )
Hotbird 13.0°E | Badr-3/4 26.0°E | Nilesat 101/102 7.0°W
Memory : 2 GB
#4Ok , but i have lost all files . so do u want a certain file ( u mention just the interface ) or the whole filesProg wrote:Yes, you need .net SDK or you can send me translated files without compilation.
thanx
OS : Win XP SP2
Memory : 2 GB
Memory : 2 GB
Arabic translation done
but there's some problems :
1. I didn't find any file have the taskbar ( File,edit,view,record ..... and the bull down menu for each ) interface
2. I didn't find any file have Server/client interface
notes :
# of resx file is 41 in main folder
# of resx file is 2 for diseq sub-folder
# of resx file is 10 for epg sub-folder
and one file MyStrings
is that right ?!
notes :
is that right ?!
OS : Win XP SP2
Memory : 2 GB
Memory : 2 GB
#7Yup i know that and i have translate all .resx files but i can't find any file include the Taskbar or server/client . i want you point to me files include these feature , plzProg wrote:You must use winres.exe. It in same folder with *.resx files.
OS : Win XP SP2
Memory : 2 GB
Memory : 2 GB
What is "taskbar"?
File , Edit, view , navigation etc. & component for each one [/quote]
OS : Win XP SP2
Memory : 2 GB
Memory : 2 GB
maybe i know why i can't these components , some *.resx files have name xform like Mainform open with lists of errors and it's not view correctly ( see picture below )
http://img337.imageshack.us/img337/7056/10113095di4.png
OS : Win XP SP2
Memory : 2 GB
Memory : 2 GB
#12it's workProg wrote:It can requst IPDev.*.dll file in same directory with resx file.
I send to you the files
OS : Win XP SP2
Memory : 2 GB
Memory : 2 GB
Hi, I have similar problem as Frozen. I want to translate ProgDVB to czech language, but I can't translate some files. If I try open e.g. MainForm.resx in WinRes I get following errors:
I have 2 IPDev.*.dll files in the resx directory.
Could you help me please?
Error - Failed to load the resource due to the following error:
System.ArgumentException: Soubor ResX Požadovaná hodnota Del nebyla nalezena. Řádek 405, pozice 5 nelze analyzovat. ---> System.Xml.XmlException: Požadovaná hodnota Del nebyla nalezena. Řádek 405, pozice 5 ---> System.ArgumentException: Požadovaná hodnota Del nebyla nalezena.
v System.Enum.Parse(Type enumType, String value, Boolean ignoreCase)
v System.Windows.Forms.KeysConverter.ConvertFrom(ITypeDescriptorContext context, CultureInfo culture, Object value)
v System.ComponentModel.TypeConverter.ConvertFromInvariantString(String text)
v System.Resources.ResXDataNode.GenerateObjectFromDataNodeInfo(DataNodeInfo dataNodeInfo, ITypeResolutionService typeResolver)
v System.Resources.ResXDataNode.GetValue(ITypeResolutionService typeResolver)
v System.Resources.ResXResourceReader.ParseDataNode(XmlTextReader reader, Boolean isMetaData)
v System.Resources.ResXResourceReader.ParseXml(XmlTextReader reader)
--- Konec trasování zásobníku pro vnitřní výjimku ---
v System.Resources.ResXResourceReader.EnsureResData()
v System.Resources.ResXResourceReader.GetEnumerator()
v System.Resources.ResourceSet.ReadResources()
v System.Resources.ResXResourceSet..ctor(Stream stream)
v Microsoft.Tools.WinRes.ResourcesLoader.BeginLoad(IDesignerLoaderHost designerLoaderHost)
