Unable to duplicate channels
Is there any way to duplicate TV channel to have in effect two copies of one channel with different audio stream (i.e. two different languages). I tried to make a copy of channel, and then change audio stream in it. Unfortunatelly that change affects both channels. Is there any other method to solve my problem?
Stations / channels are identified by SIT + TID.
If you edit one for fake IDs, to a combination, that should not exist anywhere else (like both as 8190, probably), you should find the original back at a transponder scan. Set the modified one to not update.
If doing a full scan, the fake entry will be listed as lost. But you don't have to mark it there to be deleted.
