How to change Symbol rates for Blind search?
JoSch
JoSch
Wed Feb 20, 2008 10:43 am
#1 by JoSch
In the blind search window is the Symbol rate 68750, which is wrong because it should be 6875! Also I need 6111! Can I change this rates?
  • Wed Feb 20, 2008 12:19 pm
It is impossible in current version. But I will add your values in next ProgDVB.
  • Wed Feb 20, 2008 12:43 pm
JoSch
JoSch
#3 by JoSch
Thank you!
Here is the List I got from my provider:
http://www.doktus.de/dok/49542/fernsehk ... d/xls.html
seems like I need 1725 too!
Also, is there a simple way to create a transponder list out of this? I mean simpler than entering all values manualy?
  • Wed Feb 20, 2008 12:48 pm
#4 by Prog
Impossible. I am not like make too many functions in simple form.
Give please list of all values.
  • Wed Feb 20, 2008 12:57 pm
JoSch
JoSch
#5 by JoSch
Prog wrote:Give please list of all values.
What values do you need?
The list is all I have!
  • Wed Feb 20, 2008 1:17 pm
Thanks for report. This bug already fixed. Please wait ProgTV3 update.
Prog, Fri Sep 25, 2026 10:10 am
Updating Channels -Last Impor…
Hi! I'm having this situation: I installed last two versions (3.14.4 and 3.14.5), just to be updated, but i noticed when
AndresMaxx, Thu Sep 24, 2026 2:28 am
  • It is currently Sat Sep 26, 2026 8:02 pm
