channel change slow in progdvb
1 post
ardua97
ardua97
Thu Feb 28, 2008 1:28 pm
#1 by ardua97
Hello i have a htpc vith
windows vista
AMD ATHLON 64X2 4800+
2gb Ram
and i use a skystar2
a reason that make choise to NOT use Progdvb
To se television
is the slower in cahanging channel
actually i use dvbviewer thath is faster
the fastest program i had used is Windows media center
i'm now using to make test ProgDvb 4.89.6
but the same problem was present also whith previous version
there is a solution ?
some setting ?
  • Thu Feb 28, 2008 1:36 pm
1 post
Thanks for report. This bug already fixed. Please wait ProgTV3 update.
Prog, Fri Sep 25, 2026 10:10 am
Updating Channels -Last Impor…
Hi! I'm having this situation: I installed last two versions (3.14.4 and 3.14.5), just to be updated, but i noticed when
AndresMaxx, Thu Sep 24, 2026 2:28 am
  • It is currently Sat Sep 26, 2026 7:29 pm
