problem with Kworld dvbs card and progdvb the problem some time when change from channel to other channel loss in signal (unstable signale)
and iam used 4 port diseq when select 4 port from progdvb and
A diseq nilesat
B hotbird
C badrsat
when used the 4 port diseq in progdvb the channel not found correct when ex. scan hotbird find some channel in hotbird from the nilesat the channel not correct in hotbird and some transponders not work
and when select 16 ports diseq in progdvb the all transponders work good and no any interferance btween the all satalite channel hotbird is hotbird no any + channel from other satalite but found the same problem
and when any error or freez in progdvb the dvbs card not work need restart the computer to work again.
thank you.....
