on ProgDVB 5.13.8 i see this error message when i click on settings>options
if i click esc button the message disappears but then when i click the ok button to exit options menu i see the same message again. If i click continue button nothing happens, fi i click the quit button ProgDVB closes. so there is no way to apply the changes on the options menu.
here are the details of the error message which are generated when i click the details button.
System.ArgumentNullException: Value cannot be null.
Parameter name: item
at System.Windows.Forms.ListBox.ObjectCollection.AddInternal(Object item)
at System.Windows.Forms.CheckedListBox.ObjectCollection.Add(Object item, CheckState check)
at System.Windows.Forms.CheckedListBox.ObjectCollection.Add(Object item, Boolean isChecked)
at ProgDvbNet.AudioVideoSettingsForm.()
at ProgDvbNet.AudioVideoSettingsForm.(Object , EventArgs )
at System.Windows.Forms.Form.OnShown(EventArgs e)
at System.Windows.Forms.Form.CallShownEvent()
at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
at System.Threading.ExecutionContext.runTryCode(Object userData)
at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbacks()
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400)
CodeBase: file:///c:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
ProgDvbNet
Assembly Version: 5.13.8.0
Win32 Version: 5.13.08
EngineApiWrapper
Assembly Version: 1.1.0.7
Win32 Version:
msvcm80
Assembly Version: 8.0.50727.1433
Win32 Version: 8.00.50727.1433
CodeBase: file:///C:/WINDOWS/WinSxS/x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1433_x-ww_5cf844d2/msvcm80.dll
System
System.Drawing
ProgDvbNet.bc
Assembly Version: 1.0.1.1
Win32 Version: 1.0.1.1
IPDev.Skins
Assembly Version: 1.2.13.0
Win32 Version: 1.2.13.0
ProgDvbNet.EPG
Assembly Version: 1.0.1.0
Win32 Version: 1.0.1.0
Accessibility
System.Design
enabled.
For example:
<configuration>
</configuration>
