Progdvbnet and control play
Peter1
Peter1
Fri Mar 07, 2008 6:49 pm
#1 by Peter1
Hi,
I'd like to use the command c:\progdvb\progdvbnet.exe /play "test.mpg"
Is this correct? Because the Programm makes nothing.
Thank you Peter
  • Fri Mar 07, 2008 6:53 pm
Corrent version not support this command.
  • Fri Mar 07, 2008 7:08 pm
Peter1
Peter1
#3 by Peter1
Okay, then I hope for the next version.
Peter
  • Fri Mar 07, 2008 10:13 pm
Thanks for report. This bug already fixed. Please wait ProgTV3 update.
Prog, Fri Sep 25, 2026 10:10 am
Updating Channels -Last Impor…
Hi! I'm having this situation: I installed last two versions (3.14.4 and 3.14.5), just to be updated, but i noticed when
AndresMaxx, Thu Sep 24, 2026 2:28 am
  • It is currently Sat Sep 26, 2026 8:09 pm
