Constant Crashes, all versions. Been trying to work for DAYS
I have gotten it to work ONE TIME with the original version, that came with my GENIATECH USB SATBOX card. All versions crash, but the latest 5.xxx version is the most stable. If I hit the x, it hangs even though nothing works.
I am in desperate need of help here. I can't even get it to get a signal other than sometimes it freezes on a and other bar is 62! BUT I am getting 100% of my birdog sat meter on both 119 and 110. I have also tried two different LNBS.
I am at a loss here and I consider myself an expert computer user. Below will be the "unhandled exception" error.
Im using Windows xp, all updates, including .net framework, AMD 3.2ghz, 1.5 gb RAN, 300gb SATA HD, mother board is Kv8-Max 3.
I hope someone can help, this is getting very irritating to me... :oops:
at ()
at ..()
at ProgDvbNet.MainForm.(Object , FormClosedEventArgs )
at System.Windows.Forms.Form.OnFormClosed(FormClosedEventArgs e)
at IPDev.Skins.SkinForm.OnFormClosed(FormClosedEventArgs e)
at System.Windows.Forms.Form.WmClose(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at IPDev.Skins.Docking.DockForm.WndProc(Message& m)
at IPDev.Skins.SkinForm.WndProc(Message& m)
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
ProgDvbNet
Assembly Version: 5.14.7.0
Win32 Version: 5.14.07
EngineApiWrapper
Assembly Version: 1.1.0.11
Win32 Version:
msvcm80
Assembly Version: 8.0.50727.762
Win32 Version: 8.00.50727.762
CodeBase: file:///C:/WINDOWS/WinSxS/x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.762_x-ww_6b128700/msvcm80.dll
System
System.Drawing
ProgDvbNet.bc
Assembly Version: 1.0.1.2
Win32 Version: 1.0.1.2
IPDev.Skins
Assembly Version: 1.2.15.0
Win32 Version: 1.2.15.0
ProgDvbNet.EPG
Assembly Version: 1.0.1.3
Win32 Version: 1.0.1.3
Accessibility
System.Design
enabled.
For example:
<configuration>
</configuration>
