Hi!
I bought ProgDVB Pro, but if I try to start, I get the message bda-driver not found, could not started
iam using a technisat skystar HD with technotrend s2-3200 driver, because of the 64bit problem. there are no 64bit skystar hd driver available.
so iam using s2-3200 technotrend driver.
the difference between progdvb standard and pro is the higher bda.device driver in pro-version 1.52 and in standard edition 1.51. progdvb standard detect the card and I get a sound but no video, because in the standard edition , all codecs doesnt work. I´ve tried all codecs, form elecard to intervideo, nvidia, cyberlink,
during the 14 day-test period progdvb pro works, but after registration I get the driver not found error.
I changed nothing, I dont know why the progdvb pro version cannot detect the card but the standard version of progdvb is able to detect the card, but I cannot watch TV, because the no filter and codec is accepted by progdvb standard
I tried to move the module file bda.device from the progdvb standard directory, to put in the directory "modules" in prog dvb pro,
but he doesnt detect the older bda.device 1.51
Is there any other s2-3200 technotrend driver? or a new bda.device module file, which I could try out?
Iam using version 5.0.0.19 technotrend s2-3200 driver.
the newest prog dvb pro version
i want to avoid a windows new installation and formatting
i have a 64 bit duel core processor but runninng 32 bit windows vista. can i use the 64 bit bda driver on my system?
cheers
wwe
cheers
wwe
This is not supposed to work.
