Sorting channels problem !
I want to sort channels in new channel tree with new folder . but every time i copy/paste channels from any sat ( Nilesat , Badr , Hotbird ) to the new one , ProgDvb hung and i get this error
C:\DOCUME~1\Frozen\LOCALS~1\Temp\WER6b13.dir00\ProgDvbNet.exe.mdmp
C:\DOCUME~1\Frozen\LOCALS~1\Temp\WER6b13.dir00\appcompat.txt
ProgDVB 5.14.9 Pro
OS : Win XP SP2
CPU : P4 Intel 3.00 GHz "HT"
Memory : 2 GB
DVB-S : Sky Star 2 (2.6D) ( 4.4.0 )
Hotbird 13.0°E | Badr-3/4 26.0°E | Nilesat 101/102 7.0°W
Why not use a favourites list instead?
No idea if it's still the case, but on older versions you can only change (delete, add, ...) one channel manually on a dynamic list on a session.
"Why not use a favourites list instead? "
Sorry my fault , i wrote wrong above . I meant Channel list (in favorite mode ) indeed not channel tree .
I tried to use Progedit for that . but the problem is that the application show all channels ( >3000 ) at once and there's no option like sort by sat name to make drop channel more easy .
Request for Prog ( if possible )
add a way to sorts channels directly ( without copy(cut)/paste ) .
e.g.
right click on channel(s) == > choose channel list (as a new option ) == > choose the folder name ( as a new option also )
OS : Win XP SP2
Memory : 2 GB
