New OS now my Key will not work!!!!
kijushu
kijushu
Tue Jun 24, 2008 5:19 pm
#1 by kijushu
Hello,
i bought a new Motherboard so i had to install the OS new. Now my key that i have boght for Prog DVB 5 is not working. It says please contact 'prog@progdvb.com' and it shows me my new Hardware ID so i send this tho the posted e-mail adress. My question is do i did everithing right and how long i have to wayt for my new key.
Thanks
  • Tue Jun 24, 2008 6:06 pm
Yes. If you change MB then need new key.
  • Tue Jun 24, 2008 6:15 pm
Currently, all download links on the ProgDVB website are giving a 404 error. For example, "ProgDVB Final & Preview Vers
Fikret Turedi, Tue Aug 25, 2026 1:53 pm
Sorry. Updated. https://i.hizliresim.com/w1sj3lwn.jpg Okay. For now, I can watch 4K broadcasts without any proble
Fikret Turedi, Tue Aug 25, 2026 9:25 am
Sorry. Updated.
Prog, Tue Aug 25, 2026 9:12 am
Thanks for sample. Please try prerelease of ProgDVB. https://i.hizliresim.com/smxookin.jpg Unfortunately, both l
Fikret Turedi, Tue Aug 25, 2026 8:57 am
  • It is currently Tue Aug 25, 2026 3:57 pm
