v5.15 crashes when loading the application
mutt
mutt
Tue Jul 01, 2008 10:39 am
#1 by mutt
I downloaded v5.15 and it installed correctly on XP Home sp3. When I try to run it, I get a message stating that ProgDVB has encountered a problem and must close. I installed v4.91 and this runs OK. Microsoft .NET 2 is installed. I have BDA compatible hybrid tuner card (DVB-T / DVB-S) on Medion 8800.
  • Tue Jul 01, 2008 10:44 am
Try select TSReader in installer. Still crash?
  • Tue Jul 01, 2008 4:45 pm
mutt
mutt
#3 by mutt
yes, still crash
  • Wed Jul 02, 2008 6:02 pm
#4 by Prog
What error you have? try reinstall .net...
  • Wed Jul 02, 2008 7:25 pm
mutt
mutt
#5 by mutt
As I said, the error says "ProgDVB has encountered a problem and must close" I will try re-install .net
  • Thu Jul 03, 2008 3:44 pm
Currently, all download links on the ProgDVB website are giving a 404 error. For example, "ProgDVB Final & Preview Vers
Fikret Turedi, Tue Aug 25, 2026 1:53 pm
Sorry. Updated. https://i.hizliresim.com/w1sj3lwn.jpg Okay. For now, I can watch 4K broadcasts without any proble
Fikret Turedi, Tue Aug 25, 2026 9:25 am
Sorry. Updated.
Prog, Tue Aug 25, 2026 9:12 am
Thanks for sample. Please try prerelease of ProgDVB. https://i.hizliresim.com/smxookin.jpg Unfortunately, both l
Fikret Turedi, Tue Aug 25, 2026 8:57 am
  • It is currently Tue Aug 25, 2026 3:56 pm
