i'm using progdvb v 5.15.3.0
it works very good but when i did the channel scan some channels from Nilesat 101/102 didn't appear in the list
then i downloaded a channel list and installed it these cahnnels came out in the list but didn't work
i tried ading them by frequency but the prog didn't find them
what should i do
i have a Twinhan 1027
yes it had good signal
when i added the frequency of the channel and the prog scanned it
,it found 17 already present channels but not the missing channels
No idea on Nile, but some stations may only be available temporarily.
Also check your channel list props to show all kinds of signals, as missing video IDs may lead to interpretation as Radio, missing Audio gives a Data channel.
Even this may be changing temporarily.
Do you have another software to compare with?
And, of course, the usual places for channel listings, like satcodx or lyngsat, may be partly outdated.
Holiday season, everywhere many people are out or just sitting in the pool...
well i scanned the sat again and the prog found some of the channels but it was under "Lost Channels"
what does that mean
what does that mean
it didn't work
i used other programms like alt dvb and my teatre and the same problem occured,so it isn't progdvb's problem
could it be my dvb card or my lnb
i have no idea
any way i can't thank you enough for your help
thanks
i have no idea
thanks
What transporder/channels . I can check them if u want
OS : Win XP SP2
CPU : P4 Intel 3.00 GHz "HT"
Memory : 2 GB
DVB-S : Sky Star 2 (2.6D) ( 4.4.0 )
Hotbird 13.0°E | Badr-3/4 26.0°E | Nilesat 101/102 7.0°W
Memory : 2 GB
it would be great
11765 MHz Horz 27500 SR
channel name : melody aflam
sat:Nilesat 101/102
12034 MHz Horz 27500 SR
channel name: Rotana cinema
same sat
sat:Nilesat 101/102
same sat
Tested . both channels work perfectly on different versions .
what about channels like Al Mishkat , Iqraa !
OS : Win XP SP2
Memory : 2 GB
Memory : 2 GB
Try this
h**p://www.zshare.net/download/159650188495ce34/
(**=tt)
maybe it's Horizontal channels problem ( LNB problem I think )
(**=tt)
OS : Win XP SP2
Memory : 2 GB
Memory : 2 GB
still nothing
the chanels became listed in the channels list
but not working
when i scan the transponder it finds some channels and misses some
the reciever revieves 500 channels but the dvb card recieves less than 400
but not working
May be, may be not.dr_nazy wrote:it didn't work
Some devices may be quite slow on reading NIT and other tables, due to priorities, driver issues or whatever else.
Perhaps it's necessary, to set the timeout to 5000 or even more. This would only effect a few transponders, with large and / or slowly transmitted tables, or with errors on those.
Also compare with similar settings in AltDVB.
