What does this error mean?
LoadFilter(): Class not found, CreateClassEnumerator returned S_FALSE
This Error happened to me after the space on my disk went low that I had to reset to refresh the page file of the windows. Before this crash the FlyDVB-S card was working perfectly.
After this my LifeView FlyDVB-S card refused to initiate. I usually used {BDA} tunining space or some driver like that to make it run after I re-intalled Windows XP on my computer since couple of months ago.
I tried ProgDVB4.71.4FullInstall on another computer with my FlyDVB-S however without dish. The card was defined well, so I suspect some coded problem.
I need to know what caused this error but more importantly what to do to recover this error and prevent it from coming back.
Re: What does this error mean?
#3NO, I tried ProgDVB4.71.4FullInstall
i.e version ProgDVB4.71.4FullInstall.
So WHAT This error message means?
SifeFun wrote:What does this error mean?
#5Think about adding more RAM and another hard disk. Cheaper than ever these days...SifeFun wrote:This Error happened to me after the space on my disk went low that I had to reset to refresh the page file of the windows.
Then set the record folder to a place on the other disk. Also move existing recordings there to.
If using timeshift in file, leave it on the first disk, but clean that up.
You may also want to move your temp folder, default download folder, browser cache and some other disk space eaters over, like the location for temporary files / images of your CD / DVD writing software.
BTW, how big is your existing HDD resp. the system partition on it?
Hard disks and partitions are like cabinets, occasional cleaning and sorting highly recommended. And even then, sometimes you simply need one more...
I tried the latest ProgDVB5.15.7
#6I tried the latest ProgDVB5.15.7 against my best judgement and reluctnce to install dot $hit NET "FIX"
BUT IT DID NOT WORK EITHER.
@Prog
Is THERE ANY PROGRAMMER WHO KNOWS WHERE THIS MESSAGE ORIGENATES FROM?
My best guess it's a codec issue, my worst it's a card hardware failure.
I'm furious and do not want to to reinstall windows XP and the codecs and evrey other software I use to discover that the issue is too trivial or too unfixable.
I posted here to know from the developer WHAT causes this messageand/ or how to fix it.
DID anyone else met the same issue guys.
@Prog
