The TV channels mentioned in fact are related with frequencies.
As this looks pretty German, here's a table:
http://www.vdr-wiki.de/wiki/index.php/Kanal_DVB-C
The TP numbers should relate with satellite transponders,
http://www.satcodx2.com/0192/deu/
Though, I don't really believe, they can recompress a whole 22000 or even 27500 kbps satellite transponder to a low symbol rate like 6900...
However, with the two links I gave you, and by use of the Editor / Notepad plus some effort, you should be able, to create your own transponder list, to scan with. The data you have are showing what frequencies you have and of what satellite transponders you may find (parts of (?)) the content.
Anyway, there's no must, all transponders would really have the same symbol rate and QAM. If failing on some, try other values on those.
If you find out, a few transponders had spectral inversion different from the others, you may perhaps have to create a second list for those.
