progdvb 4->5 problem
hi
i have a problem
first my english is not that good...
the problem you could help me with is:
i used the 4.** version of progdvb a long time and it works fine. no i wanted to test the 5.**
but now i get a error message: "h.264/avc and dvb-s2 supported only in pro version"
did they support that in the free version of the 4.** version??
(the pro shareware version works fine)
or do i have to change some of the default settings?
same codecs (elecard), budged pci card (nova)
thx for help
h.264, AFAIK partly, on a few pretty old versions.
DVB-S2, no. But the normal Nova can't tune to that anyway.
ok, thougth so too.
it works now
i erased the channellist und did a new scan (is just copied my old list last time)
still a bit strange...
