Have just started with ProgDVB5.15.9Pro (trial)
Faced two problems:
1- Could not activate english audio stream out of two available streams. Default being Polish (12265 on Hotbird, HBO-HD TEST)
2- In satellite scan (Hotbird @13E), 12130H was missed. After repeated efforts through transponder scan, finall got it (why so much effort for this transponder ?)
WinXP-SP3
Intel P4-HT 3.0 GHz
nVidia GeForce 7600-512MB
SkyStar-2 Rev.2.8A (drivers 4.4.3)
Nexus-S Rev.2.1
Memory: 1022MB RAM
2)
Perhaps your LNB's LOF in use deviates a bit, or the transponder list used is not precise. Try to scan one - two - three MHz up and down, on more than one transponder, try to find an individual or systematic deviation for the hold range centre, versus the nominal value from Eutelsat or satcodx.com
Individual -->correct transponder list entry
Systematic --> correct LOF in use, for that amount into the opposite direction
1)
- sorry, no idea, my hardware does not allow HD -
Thanks Juergen !
WinXP-SP3
Intel P4-HT 3.0 GHz
Nexus-S Rev.2.1
Memory: 1022MB RAM
