Lots of users using HTPC, they usually set Operating system font size to 120dpi,
but in 120dpi, the ProgDVB default disabled skin will look strange. The fonts on menu bar will only display a part.
The timeshift time will also not display fully on bottom right corner..
To solve this, I need to use the "blue skin", but using this skin, there will be no percentage numbers display for signal level and quality on the status bar...
Please check and hope this will be solved soon..
ProgDVB skin issues when OS font size set to 120dpi
#1Windows 7, 64-bit.
Twinhan AD-SP400(1041) DVB-S2.
KNC1 DVB-S2.
Technotrend S2300 Premium DVB-S.
Technotrend C1500 DVB-C.
Technotrend DVB-T TV-stick.
ATI 4550.
Asus Xonar HDAV1.3 Deluxe.
Creative S750 speaker system.
Latest ver.6 of ProgDVB Pro.
KNC1 DVB-S2.
ATI 4550.
