iam used version progdvb 5.15.10 ( 32 bit)
the problem
when need edit in the option select
settings
options
other
i need select refesh channel on lost signal ( because i found problem with my dvb card kworld when go from channel to other channel some time lost the signal )
when select the ( refesh channel on lost signal )
when exit from progdvb and then restart the progdvb the selective
( refesh channel on lost signal ) is not active ?
the progdvb settings in
C:\Users\my user\AppData\Local\ProgDVB
Re: problem in progdvb 5.15.10 and vista x64
#4What exactly do you mean?man2007 wrote:...when exit from progdvb and then restart the progdvb the selective
( refesh channel on lost signal ) is not active ?...
Station not selected? Or just not set active in your channel list? To find out, tune to another channel and try if you can go back to the previous channel then.
Or tuner not initiated?
Any error message?
BTW, the channel refresh should happen automatically, without having to restart ProgDVB.
thank you
i mean this
when active the selection after exit from progdvb the selection not active
( not enable) in next restart progdvb
i whant enable this selection because
some time in hotbird (diseq used port A)
when change from channel to other some time lost signal
i mean this
I see.
Means, the selection is not getting stored for that option.
Obviously a bug.
Hope Prog reads this.
Meanwhile you may try to change from ProgDVB.ini
In older versions this was located in "Options":
"ResfeshLevel=0", to be changed to "ResfeshLevel=1".
(No typo here, I've just used copy & paste)
AFAIK it's still the same on newer versions.
If that entry does not exist, try to add a line for this.
And perhaps post that whole "Options" section here.
Obviously a bug.
when change
ResfeshLevel=1
or =0
no any change
can not true reading from progdvb
always reading disable not enable
ResfeshLevel=1
or =0
no any change
