NOTONLYTV PCI Supported???
I have a NOT ONLY TV Hybrid PCI dual dvb-t/analog and I have 2 problems. When I scan the channels with "BDA Card Device" or "Auto[unknown]" I get, for each frequency, the same programs and they will repeat for all frenquencies.
If I choose Lifeview Card Type the progdvb crash and after few minutes I get the BSOD with error on KS.SYS.
I tried to choose TwinHan and scan works quite fine, but when I change channel from "Italia1" and "RAI" the progdvb tv screen stays black with no images. I tried another software and the channels are displayed correctly but I can't record so I need to use progdvb, but I can't get it work correctly.
Any suggestions?
thanks in advance
