i have twinhan 1025 with xp SP3 i was working with bad driver but now i switch back to wdm driver .the problem is i want to use my channel list that created under bda driver and the prog refuse(there is signal but no audio and vedio) i tried old channel list created under wdm driver and it work but it was too old and i want to use the my last channel list that created under bda driver what the problem?.
Edit:
i use the last version 4.91.11 std
I want to let u know:
I told my friends about this problem and one of them send me an old thsource.ax i register it and it works now i can use bda channel list on wdm driver but i only can watch not update channel list because if i do scan it makes new sat that means channels didn't update but the prog makes new list.
