I would like to start Teletext without duty clik on the icon Teletext.
I explain the motive: The morning I am not present so I start my PC from BIOS and the driver of the modem Sky Star 2 and ProgDVB with execution automatic programs.
To this point I would Like to start Teletext without duty clik on the icon Teletext to record in file folder TTextCache.
It is possible
(I Use the ProgDVB 4.74 - XP Pro)
Thanks.
Re:Teletext
#3I have installed ProgDVB 4.91.12 and all it regularly works.Prog wrote:You can try modern 5.x versions.
My problem remains.
How can I start teletext with the start of ProgDVB?
Thanks.
