Hello!
I have a problem. I use Cinergy S2 PCI HD with CI.
I would like to encrypt ORF with the CI Modul and Smartcard with CryptoWorks. The Modul is within the newes software.
In the latest version and older the program dont find the Modul and information on the smartcard. The program dont encrypt the Cannals. Whats the problem??
Any idea?
I hope for help
Galgenvogel31
PS: I use the latest driver for the TV Card
Cynergy 2S CI
#3The original Software runs with the newest CI Modul and driver. Win XP Pro all updates.
But ProgDVB not. However you do it dosent work.
Dear galgenvogel31
Dear galgenvogel31
ORF use simulcrypt, so perhaps you should set the Cryptoworks ECM as default in channel properties.
That's ECM 20* ~ CA-ID 0xd05.
Try this even if the CI menu won't show up. Switching away and back once may be required.
Hi.
I have the same Terratec Cinergy S2 PCI HD card, a cryptomodule and an ORF smartcard.
Newest BDA driver for Terratec Card.
I can run (and see) ORF without additional settings in MediaPortal.
I am using ProgDVD 5.15.09 (as the newest version hangs on changing the channel order).
I don't understand the last posting
"That's ECM 20* ~ CA-ID 0xd05." ??
Is it the Channel Properties - PIDs tab? And is the asterix (star) for any number?
In the tab Conditional Access: Type=0xD05, ECM=201, EMM=0xC9, ID=0000 etc.
But I still can not see ORF.
Please help me as I really DON'T want to use a sofware for ORF encryption as I have a working HW and smartcard for which I am paying.
b.r.
bart
b.r.
bart
Yes.bart0190 wrote: "That's ECM 20* ~ CA-ID 0xd05." ??
Asterix is for the station specific ECM. Those must be unique on a transponder and therefore change within a range, from one station to the other, whereas Type normally stays the same for a crypt system.
It doesnt work.
i changed the ecm to 201 but no sound and no picture.
might i need another setting?
as it works with media portal it is kind of anoying that i can ot make it run with progdvb.
does somebody have another idea what i might have forgotten?
