sinds 4 months i have som activation problems the program can't handle multiple harddrives till now i have 10 hardware ID's for the same system
it is different per OS and in the beginning i get onother ID each time i connected a harddrive on the USB port
in the latest version s (till 16.1) i got an alternated ID so two numbers random choosen by the system the problem is you can only use one key if you try to register the second key on the site the first key is automaticly is blocked i ask for two codes but i didnt get any reply on that
now it is just a russian roulete if i get the wrong number i have to restart the PC and hopefull i got the right key
it is a known problem on the site but already for 4 months they didnt com with a solution
does anyone has a fix or path for this solution becouse i get qa little bit irritatat on the fact that i have a 50 % chanse to have to reboot the system before i can use ProgDVB
I don't really know anything about the mechanics behind the HW ID generator, but from my point of view, USB devices should not be involved with this in any way, specially not external storage.
Else I'd tend towards calling this bad behaviour of some software component, or at least a really bad bug...
Only Prog may be able to tell more
