streaming Transponder over LAN
georgeKS
georgeKS
Thu Oct 16, 2008 7:22 am
#1 by georgeKS
1) is it possible ProgDVB streaming whole tranpsnder over Lan simultaneously? (DVB-S over IP) i have Amino110 SET TOP BOX for encoding
2) can i use more than 1 Pci Cards, so ProgDVB can stream more than one transponder simultaneously rebroadcast.
Thanks
  • Thu Oct 16, 2008 7:31 am
1. I am disable this function because huge traffic. Usually 100mbit network not good for that.
2. In Pro/large.
  • Thu Oct 16, 2008 9:22 am
#3 by Prog
1. You can choose channels which to really you are necessary and to stream they in iptv a mode.
  • Thu Oct 16, 2008 9:24 am
Currently, all download links on the ProgDVB website are giving a 404 error. For example, "ProgDVB Final & Preview Vers
Fikret Turedi, Tue Aug 25, 2026 1:53 pm
Sorry. Updated. https://i.hizliresim.com/w1sj3lwn.jpg Okay. For now, I can watch 4K broadcasts without any proble
Fikret Turedi, Tue Aug 25, 2026 9:25 am
Sorry. Updated.
Prog, Tue Aug 25, 2026 9:12 am
Thanks for sample. Please try prerelease of ProgDVB. https://i.hizliresim.com/smxookin.jpg Unfortunately, both l
Fikret Turedi, Tue Aug 25, 2026 8:57 am
  • It is currently Tue Aug 25, 2026 3:09 pm
