by Juergen
Obviously this is a multiswitch for the German market.
Such would have four inputs for each satellite.
14 (or 13) / 18 Volts would be used for polarisation switching, 14 Volts for vertical, 18 Volts for Horizontal.
22kHz would be used for band switching, off for Low Band, on for High band.
For each position, don't mix them up...
All this means, each of your Quattro LNBs provides four output ports, that must be connected to the multiswitch properly:
LV to the port with 14 Volts, 0 kHz / 22kHz off
LH to 18 Volts, 0 kHz,
HV to 14 Volts, 22kHz (on)
HH to 18 Volts, 22kHz
If you mixed up the lines in any way, your software would not be able to switch properly. You MUST NOT use 22kHz for satellite switching, as we did in early analogue days, up to fifteen years ago. Else you can't access half of each position these days. Have the Hyundai use DiSEqC for satellite position. If necessary, change LNB lines to the schedule mentioned above, for both LNBs. Verify carefully!
Voltage and 22kHz switching components of your mutiswitch are NOT entered into the LNB / DiSEqC setings, as they behave absolutely identical with Single (Universal) LNBs.
But a multiswitch with eight satellite input ports also includes a DiSEqC switch stage, normally DiSEqC 1.0 or ToneBurst, that must be entered in your LNB / DiSEqC settings, two LNBs connected there to, each to the correct port (first / second position).
