dear friends,
I have ProgDVB 4.80+SkyStar2 and when i start the program the normal (not encrypted channel stops sudennly or cuts from time to time the turn back.
how can i fixed these problem to have constant streaming???
I am a beginner and i need exaktly informations how to doo.
help!
Hi
I'm also having same problem/bug with the same configuration.
I ve progDVB latest version with SS2 new version
While I'm setting the channel for DATA to grab files using Skygrabber, after few minutes/hours progDVB shows no signal for that DATA stream.. means it also does not work for any other FTA channels. I'm forced to restart progDVB again
Any solution ????
Any solution ????
i can not reproduce this...using 4.80.x freeware version and several codecs (Elecard,ffdshow,cyberlink 6 etc..)
Skystar 2 rev. 2.3x and technisat driver 4.40 ...working like a charm....
May be progDVB does not like my face (computer)
Me also using freeware version 4.80.5, SS2 2.6D, Technisat 4.40.. driver
Last night I left the Skygrabber for downloading but when I woke up morning seen that progDVB is not streaming the signal
I do not know wts wrong in my PC/progDVB
I ve AMD processor with ASUS MB.
Can it be a source to the problem ?
i don´t think so...i have a Intel P4 and a AMD pc...both working fineI ve AMD processor with ASUS MB.
Note that in the SkyStar 2 documentation, it states that the SS2 cards are not compatible with Asus nVidia nForce 4 chipset based motherboards (page 2 of the FAQ, section 1.1 Installation of Hardware). I had a Asus A8N-SLI MB and the SS2 card only worked intermittently in it.
