Hi,
using dvbprog pro 6.02 test. when trying to look HD channels I got the messega to set the codec in options directshow custom mode, but in 6.02 there is no direct show tab in options? How can I set a custom HD codec??
Why do I get then the info message to activate custom mode?
The H263/AVC is set to Nero Video decode HD, Video Renderer si set to VMR-9.
Every time I choose a HD channel get an info message to switch to custom mode...
s2tester
Language is English,
and as always you are right, tested with the tt codec and it works, but if you maximize on a secondary monitor picture freezes...
s2tester
